MCode Data Type Mismatch
I designed a simple FSM using MCode. The FSM is used to increment a config variable. The code is as below,
function [configValid,configFsel] = coefficientSwitch(tready)
    % switches between the coefficient sets to configure the config channel
    %#codegen
    nCoeSets        = 2;
    bCoeID          = xl_nbits(nCoeSets-1); % =1
    % State definitions
    START      = 0;
    SWITCHING  = 1;
    bState     = xl_nbits(2); % Number of bits to represent a state
    % Assign registers for all output and intermediate variables
    persistent configValidReg, configValidReg = xl_state(false,{xlBoolean});
    persistent configFselReg, configFselReg = xl_state(0,{xlUnsigned,bCoeID,0});
    persistent stateReg, stateReg = xl_state(START,{xlUnsigned,bState,0});
    %% Switching
    if(tready) % data reception starts
        switch double(stateReg)
            case START
                % Assert the Valid flag
                configValidReg = true;
                configFselReg = xfix({xlUnsigned,bCoeID,0},0); % First coe set
                stateReg = SWITCHING;
            case SWITCHING
                % Switching to the next coefficient set
                if(configFselReg == nCoeSets-1)
                    configFselReg = xfix({xlUnsigned,bCoeID,0},0); % reset when reached max count
                else
                    configFselReg = xfix({xlUnsigned,bCoeID,0},configFselReg + 1);
                end
            otherwise
                configValidReg = false;
        end
    else
    end
    % Assign outputs
    configValid = configValidReg;
    configFsel = configFselReg;
end
I expect the output configFsel to be 1 bit (because the number of coefficients is 2, one bit is enough to represent it). I have assigned only one bit for it throughout the code,
bCoeID = 1;
However at the output, it is assigned with 4 bits after compilation. I have no idea why? Any help would be appreciated!
Bhavanithya Thiraviaraja
回复: MCode Data Type Mismatch
What's value of bCoeID?
bCoeID = 1
It might be due to following syntax.
                else
