HeroGian91
MicroBlaze and AI Engine interaction
Hello, I am following this tutorial https://github.com/Xilinx/Vitis-Tutorials/tree/master/AI_Engine_Development/Feature_Tutorials/01-aie_a_to_z and I learned the AI Engine core can be controlled with both A72 and R5 cores.
I am wondering if it is possibile to control the execution of an AIE graph also with a MicroBlaze core.
It is possible or it is not supported yet?
Tags (3)
florentw
HI @HeroGian91
Controlling the AI Engine graph from a Microblaze is not supported yet. (I am not saying that it will be and I am not saying that it won't be. It might be supported in the future)
Florent
florentw
HI @HeroGian91
Florent
