guidopc
Model Composer (2017.4)
ERROR: MATLAB R2018b is not supported by Model Composer.
Is it for real? shall I update to Vivado 2018.latest and download the latest MC to work with MATLAB R2018b? or any MC release does work only with MATLAB R2017 or earlier? In that case forget about MC: is a dead product!
meherp
Although you can use Matlab R2018a with Vivado 2018.3 versions.
Also, in next release Matlab R2018b and R2019a will be supported.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
meherp
guidopc
Thanks, but I stay with what I said: a product needing MATLAB but not supporting the latest MATLAB release has no future (and no present!)... pity!
