oguzhan.cik
Model Composer 2020.2 and MATLAB R2020b problem on Ubuntu
I'm using Vitis 2020.2 installation on Ubuntu 20.04 with Matlab 2020b. When I try to open Model Composer using xmc_sysgen command from terminal, I get the following errors:
/usr/local/MATLAB/R2020b/bin/glnxa64/cef_helper: symbol lookup error: /lib/x86_64-linux-gnu/libgnutls.so.30: undefined symbol: __gmpz_limbs_write
After getting them Matlab is opened but Simulink window cannot be opened related to this errors. When I try to open Matlab2020b without Xilinx extensions, I don't get this error and simulink is opened succesfully.
I need a solution for this issue caused by Xilinx extensions.
miker
@oguzhan.cik Please reference the Vivado Design Suite Release Notes, Installation, and Licensing User Guide (UG973; v2020.2) in Table 2: Compatible Third-Party Tools.  MathWorks MATLAB and Simulink versions supported by Vivado/Vitis 2020.2 are R2019a, R2019b, and R2020a.
Please Reply, Kudos, and Accept as Solution.
miker
mohammadhgh
@miker Is there inconsistency between UG973  and UG1483, as in UG1483 it indicates that MATLAB R2020b is also supported?
miker
@mohammadhgh
Good catch.  There is supposed to be consistency.  I will report the inconsistency and have them correct the documentation.
viswanad
UG973 is already updated to be in sync with the UG1483. It should be out soon with updated MATLAB version support.
mohammadhgh
@miker I tried both MATLAB R2020a and R2020b with Ubuntu 20.04 and still get the same error. When I open a Simulink window, the following error is shown in MATLAB command windows and when the Simulink window is open the header is empty.
cgrant
@miker, @viswanad, I am also experiencing what @mohammadhgh is seeing. Matlab 2020b seems to be fine opening windows when opened using the matlab executable, but when I open it using the "sysgen" executable (Vivado 2020.2), I get this error in Matlab:
>> cd(matlabroot)
>> ! bin/glnxa64/MATLABWindow
bin/glnxa64/MATLABWindow: symbol lookup error: /lib/x86_64-linux-gnu/libgnutls.so.30: undefined symbol: __gmpz_limbs_write
Why is GMP missing? Do I need to install GMP separately?
kbandura
I have the same trouble.  Things 'run', but I cannot open a Xilinx block in simulink.
Hi, I have that problem and was solved just cleanen de cache of google chrome in /home/$USER/.cache/.google-chrome/
But now I have the same problem as mohammadhgh @mohammadhgh , @cgrant and @kbandura ,
>> cd (matlabroot)
I run sysgen with Vivado 2019.2 and MATLAB 2019.b on Ubuntu 20.04.01
Linux graslilie 5.8.0-49-generic #55~20.04.1-Ubuntu SMP Fri Mar 26 01:01:07 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
canisio
Hello @miker
This solution is not working. I've tried with Matlab 2020a and 2020b and I'm getting the exact same error described by @mohammadhgh  and @oguzhan.cik
I'm using Ubuntu 20.04 LTS, Matlab 2020a and Vivado 2020.2. What I'm missing?
kbandura
What actually worked for me was to install the KDE desktop environment.  I believe I followed this:  https://itsfoss.com/install-kde-on-ubuntu/
Everything then worked for me on the KDE desktop, or standard Ubuntu Desktop.
canisio
Just tried KDE and the errors are exactly the same. It did not work. Thanks anyways.
I'll wait to see what's Xilinx position...
