maomaoliu
Model Composer Error reported by S-function 'XilinxLibrary' in 'xmc_sobel_edge_detection/edge_detection/Sobel Filter':
viswanad
Can you please tell, on which OS(Windows-7 or 10) you are facing this issue? Share the version of matlab also.
I see from you diagnostic viewer window that, you are using 2017.4 version. Am i correct?
Viswanadh
maomaoliu
window10
vivado2017.4
matlab2016
abehbood
After looking into this issue, we believe the problem is your MATLAB working directory is not writable (E:\xilinx\Model_Composer\2017.4\simulink) .Please change your MATLAB working directory to a folder that you have write permission and then run the Sobel Edge Detection model again.
For example, you can use this command cd(tempdir) in MATLAB command window to change the directory to your temp directory and then run the model again.
Thank you
