[Model Composer] Huge BRAM usage when using custom blocks
Hallo,
I'm trying to working on a Bayer-Sensor video format in Model Composer.
My IP-Core get a bayer-pattern video (BGGR) as input and output. It should apply four diffrent gain values to the coresponding pixel.
For that I build a custom block in C:
#include <stdint.h>
template <int HEIGHT, int WIDTH>
void gain_bayer_bggr(const uint16_t in[HEIGHT][WIDTH], const uint32_t gain, uint16_t out[HEIGHT][WIDTH]) {
	uint16_t gain_b  = (uint16_t)(      gain & 0xFF);
	uint16_t gain_g1 = (uint16_t)((gain>>8)  & 0xFF);
	uint16_t gain_g2 = (uint16_t)((gain>>16) & 0xFF);
	uint16_t gain_r  = (uint16_t)((gain>>24) & 0xFF);
    for (int i = 0; i<HEIGHT; i++) {
		for (int j = 0; j<WIDTH; j++) {
        	#pragma HLS PIPELINE II=1
            if(!(i&1)) {
                if(!(j&1)){
                    out[i][j] = in[i][j]*gain_b;
                } else {
                    out[i][j] = in[i][j]*gain_g1;
            } else {
                if(!(j&1)){
                    out[i][j] = in[i][j]*gain_g2;
                } else {
                    out[i][j] = in[i][j]*gain_r;
My top-level-subsystem has two inputs and one output. One input and the output are defined as axi4-stream (video) mono. At the second input, the gain factor is applyed. The video resolution is 2560 x 720 pixel.
After compiling, the report show me 186% BRAM usage.
    * Memory:
    |         Memory         |        Module        | BRAM_18K| FF | LUT|  Words  | Bits| Banks| W*Bits*Banks|
    |VideoIn_adapter_out1_U  |gain_bayer_bggr_mcud  |     1688|  32|   0|  1843200|   16|     1|     29491200|
    |gain_bayer_bggr_main_U  |gain_bayer_bggr_mcud  |     1688|  32|   0|  1843200|   16|     1|     29491200|
    |Total                   |                      |     3376|  64|   0|  3686400|   32|     2|     58982400|
Is it possible to work with huge videoresolutions like this?
How can I prevent xmc to save the input image in the ram?
Best regards
Sebastian
Hi Sebastian,
Please take a look at the 2018.3 user guide (UG1262, page 46). You need to explicitly tell the tool that the funciton you are importing supports streaming. The user guide explains what that means. Once you do that, you will see that your BRAM usage will be very little.
I took your example and added the pragma at the top.
#include <stdint.h>
#pragma XMC SUPPORTS_STREAMING
For my device, the desgin uses only 4 BRAMS.
Please try this and let me know if it works for you.
Hi Sebastian,
#include <stdint.h>
many thanks. Now it works much better.
Not as less resources as a XSG-solution but better.
Sometimes it is better to read a document with open eyes. :-)
Sebastian
