[Model Composer] libgmp problem
I am try to launch Model Composer 2017.4 and 2018.2 on Ubuntu 16.04 with Matlab 2017.a
I launch Model Composer via terminal using following commands:
cd /opt/Xilinx/Model_Composer/2018.2/bin/
./model_composer
But after Matlab launched i have recive a lot of errors:
Invalid MEX-file '/opt/Xilinx/Model_Composer/2018.2/lib/lnx64.o/xmcPathInfo.mexa64': Missing dependent shared libraries:
'libgmp.so.7' required by
'/opt/Xilinx/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx/Model_Composer/2018.2/lib/lnx64.o/xmcPathInfo.mexa64'
Missing symbol '_ZdaPv' required by
'/opt/Xilinx/Model_Composer/2018.2/lib/lnx64.o/libXil_lmgr11.so->/opt/Xilinx/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx/Model_Composer/2018.2/lib/lnx64.o/xmcPathInfo.mexa64'
Missing symbol '_ZnamRKSt9nothrow_t' required by
Missing symbol '_ZSt7nothrow' required by
Missing symbol '__gmp_bits_per_limb' required by
Missing symbol '__gmpf_clear' required by
Missing symbol '__gmpf_get_str' required by...
I tryed install GMP 6.1.2 from https://gmplib.org with --enable-cxx option but this is didn't help.
Could You help me to resolve this problem?
Sorry for my english.
Re: [Model Composer] libgmp problem
Update: Model Composer 2018.3 now supports Ubuntu
As always, for a list of supported OSes for Model Composer, you can refer to the "Compatible Third-Party Tools" table 2-2 in the Vivado Design Suite User Guide: Release Notes, Installation and Licensing (UG973
Thank you.
I hope that Xilinx in future will develop Model Composer for Ubuntu
Observer bhatmahadev6
Re: [Model Composer] libgmp problem,I am getting this error even if it is compatible with Matlab 2017a
Invalid MEX-file '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64': Missing dependent shared libraries:
'libgmp.so.7' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '_ZdaPv' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libXil_lmgr11.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '_ZnamRKSt9nothrow_t' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libXil_lmgr11.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '_ZSt7nothrow' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libXil_lmgr11.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmp_bits_per_limb' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpf_clear' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpf_get_str' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpf_init2' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpf_set_si' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmp_get_memory_functions' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpn_popcount' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_add' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_add_ui' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_and' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_cdiv_q_2exp' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_clear' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_clrbit' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_cmp' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_cmp_si' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_com' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_combit' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_fdiv_q_2exp' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_get_d' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_get_si' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_get_str' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_init' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_init_set' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_mul' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_mul_2exp' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_mul_si' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_mul_ui' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_scan1' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_set' required by '/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfpo_v70.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/libfourier.so->/opt/Xilinx2/Model_Composer/2018.2/lib/lnx64.o/XilinxCompiler.mexa64'
Missing symbol '__gmpz_setbit' required by '/opt/X
