anaub408
ModelComposer MaskDialog Error
I am using Matlab2018b and Model Composer 2018.3 on a Ubuntu machine.
When I'm trying to change my project device in the Model Composer Hub I am getting an Error Window with following:
Error evaluating 'MaskDialog' callback of Implementation block (mask) 'xmc_sobel_edge_detection/Model Composer Hub'. Callback string is 'xmcHubDeviceButtonPressed(gcbh);'
Reference to non-existent field 'ProductCategory'.
Is there any known bug in this release? Or is there an other way to change my device?
Thank You.
abehbood
This issue is now resolved and the fix will be in the next upcoming release of Model Composer. Thank you very much for the input.
meherp
The Matlab 2018b is not supported by Model composer 2018.3.
Please try with Matlab 2018a.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
anaub408
sorry, typing error, my mistake.
It is 2018a
ukumar
Could you please confirm that you're using Model Composer 2018.3 with MATLAB R2018a on Ubuntu ?
Are you able to simulate or generate code from examples without any issue ? Is the problem only when you try to change the device using the Model Composer Hub block ?
anaub408
Yes, I am using Matlab 2018a with Model Composer 2018.3 on Ubuntu 16.04
- MATLAB Version: 9.4.0.949201 (R2018a) Update 6
- Model Composer v2018.3 Build 2405991 on Thu Dec 6 23:41:51 MST 2018
And yes again, the problem only occurs when I'm trying to change the device with the GUI in the Hub block. When trying to change the device, the error window and the new window containing the lists of the parts / boards opens but I'm not able to select one or apply my changes.
When opening the saved model with an editor, I can change the device "manually" by editing the line in the model code. And then simulate or generate code for the correct device without any other errors occuring.
So it seems to be just an error inside the GUI.
abehbood
Greetings,
We have been trying to re-produce the issue at Xilinx, but we have not been able to. I see your error message referes to a "product category" field missing. Can you let us know if you see a Product Category column in the device list that opens up?
anaub408
thanks for your help fixing this little issue.
The titles of the columns are in the first line and not where they may belong to.
abehbood
Thank you very much for the input. We will continue to look into this and try to reproduce it. In the process, we may need your help. Meanwhile, looks like you have a work around and are not blocked by this issue. We appreacite any other input you may have as you are using the tool.
abehbood
s-engel
I'm just starting to evaluate ModelComposer and get the same error.
I'm using Vivado 2018.2 and Matlab 2017b on a Windows x64 machine.
And i just got the 90-day trial today for ModelComposer.
Is my problem fixed with the next release, too?
Thank you.
abehbood
Yes, this issue will be resolved in the upcoming 2019.1 release of our software.
