Multiple FFTs using Coregen
Hi all,
Is there a way to configure the FFT core in coregen to compute FFT of two complex sequences simultaneously?
I can use to seperate cores to do this operation. However, this means that we creating memory for twiddle factors twice (which is redundant). Any ideas or suggestions on how to do this? I am planning on using pipelined I/O Streaming.
Thanks in advance
Re: Multiple FFTs using Coregen
The FFT does support multiple channels.  Is this what you wanted?
Chris
Video Design Hub | Embedded SW Support
