Need help with DDS compiler v6 C model in Matlab
Using the DDS compiler V6 from Vivado 2015.2, have no problem generating IP, but when I try to compile the C model in Matlab (following the instruction from the programming guide), the following error message shows up:
dds_compiler_v6_0_bitacc_mex.obj : error LNK2019: unresolved external symbol xip_dds_v6_0_data_do_signed referenced in function "void __cdecl do_run(enum mex_opcode,int,struct mxArray_tag * * const,int,struct mxArray_tag const * * const)" (?do_run@@YAXW4mex_opcode@@HQEAPEAUmxArray_tag@@HQEAPEBU2@@Z)
dds_compiler_v6_0_bitacc_mex.mexw64 : fatal error LNK1120: 1 unresolved externals
Attached is the Vivado generated c model zip file.  The Matlab script that causes the error is "make_dds_compiler_v6_0_mex".
Please help!
check these thread
https://forums.xilinx.com/t5/Digital-Signal-Processing-IP-and/Xilinx-xfft-8-0-Cmodel-Compilation-Error/td-p/549324
https://msdn.microsoft.com/en-us/library/799kze2z.aspx
Thanks and Regards
Balkrishan
The linker can't find the shared libraries that come with the cmodel. Are you using linux or windows?
www.xilinx.com
I am using Windows 7 pro 64bit with Matlab R2012b 64bit and Microsoft Software Development Kit (SDK) 7.1
Thanks!
The matlab code still don't work. Please help!
Can you please download C model from this ARs and try to run.
http://www.xilinx.com/support/answers/66025.html
Thanks and Regards
Balkrishan
