ThomasMoeller
Opening Vitis-HLS Core from Model Composer
in the Model Composer, I have a design with several Vitis HLS cores. Double Clicking on the core opens the dialog, where you can tell the software where to find the solution. This dialog has an "Edit" button, which has no effect on my system. I would expect that Vitis HLS would be opened with the correct project. Unfortunately I did not find any error messages.
In the 2019.1 System the System Generator opens Vivado HLS when cloicking the "Edit" button.
Could you tell me what I am missing? I will be happy to provide additional information (e.g. log-files) if you tell me where to find it.
vkanchan
Which version of Vivado and MATLAB are you using ?
ThomasMoeller
Hello vkanchan,
I am using Matlab 2020b Update 5 and Vitis 2020.2.2.
vkanchan
Hi @ThomasMoeller
The browse button allows to refer to the HLS solution which has been exported to Sysgen format.
However the "Edit" button does not work here.  This is identified as a bug in the Vitis HLS block functionality. I have created a change request and it will be addressed in the future release.
