PC-CFR 6.3 MATLAB NR Simulation
Hi, I am trying to use the MATLAB model supplied for the PC-CFR v6.3 IP to simulate various NR bandwidths.  There is an example with 2 x 100 MHz NR where the MRAT_SPEC.rat_type = {'NR100_TM'} to specify the waveform mat.  I can see that there are also 5, 20 and 60 MHz BW NR waveform mat files.  If I logically try to set the rat_type to NR20_TM the simulation errors out with the following error:
Error using make_mc_data (line 74)
Invalid signal_name...
So, my question is what value should be used for MRAT_SPEC.rat_type to allow the 5, 20 and 60 MHz BW NR waveforms to be used in the MATLAB simulation?
Frank
HI @axisnt
This can't be done with existing Matlab Model for CFR 6.3 or earlier.
Please create a service request for it; and we will provide the patch for it.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
