FarajiRasoul
Problem with 1024-point FFT configuration
Hi All,
I am trying to configure a 1024-point FFT IP core. I tried to use unscaled FFT as well as scaled ones but I cannot get the same or almost the same results as Matlab FFT functions. I do not use cyclic prefix. For unscaled, I set the configuration to 16'h0001 and for the scaled version I used 22222 and 22223 for SCALE_SCH but it seems that it does not work. I should mention that for 512-point and 256-point it works. I would really appreciate if you could help to figure it out.
-Rasoul
vkanchan
Hi @FarajiRasoul ,
is the IP MEX function being used to compute the FFT? If so, are the input values quantized when provided to the Xilinx FFT function ?
FarajiRasoul
Hi @vkanchan
Thanks for your reply. I have used the IP in Vivado and simulated it with XSIM. The input values were quantized.
nathanx
@FarajiRasoul , can you share your unscaled FFT IP parameter configuration and Matlab M code?
FarajiRasoul
Hi @nathanx
I have attached codes and an image that shows how I have configured my FFT. I have used Matlab FFT to validate Xilinx FFT output values. The output values of Matlab FFT are not exactly the same as Xilinx FFT, however, they are close. The output values that I have got using the configuration and attached files are way off from Matlab FFT outputs.
