varsha_14b
Problem with start_debug_interface of dpd_v9_0_dbg on matlab environment
Dear Sir / Madam,
I'm trying to run the command start_debug_interface in MATLAB 2018b command window. We face the following errors upon executing the same -
Operands to the || and && operators must be convertible to logical scalar values.
Error in jtag_init
Error in start_debug_interface
My system OD : Ubuntu 16.04
Vivado Version : 2018.3
Kindly help with regard to rectifying this error.
meherp
Hi Varsha,
There is one document in the DEMO lounge with name "DFE Demo with ZCU111 and XRF3/XM500 User Guide v0.3"
Try to follow the steps in that document.
May be check it with your Xilinx representative to fix the issue. If required, please file a SR for it.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
