joancab
Advisor
Advisor
RS decoder stops because of eval license?
I'm using the RS encoder and decoder and I noticed it stops decoding in the middle of the second block.
This is the decoder output, each block is 239 bytes:
And this is the encoder's output, Tlast is high at the end of each block so more than 3 blocks were sent to the decoder.
I'm using them with the eval license that I know it's time-limited but I hoped it was longer than microseconds!?
joancab
Advisor
Advisor
I managed to encode/ decode at least 8 blocks, I believe it was the DMA not taking any more data after seeing the Tlast at the end of the 1st block.
