Reed Solomon Encoder outputs "NaN" in System Generator
Hallo community,
I built a SysGen model with the RS Encoder block involved. When I simulate the design, RS gives "NaN" (not a number) at all of its ouputs. Do I need a license for simulation in SysGen? I can't find any information about that.
Thank you
Stefan Schwarzer
Well, I retrieved an evaluation license and now simulation works as expected. I don't blame Xilinx for that, it's normal business. But please, please, please write that down in the SysGen documentation somewhere!
Ensure the input to RS Encoder are valid, try to use valid in and valid out for each block.
I think I did everything correct, but I still get the NANs. Could you please take a look at the model attached? I am using Xilinx 12.1 and Matlab 2010a. I know 2010a is beta for SysGen 12.1, maybe that is the problem!?
Stefan Schwarzer
Nope, same problem with 2009b.
So is it the license or did I do anything wrong in the model?
I remember it only occurs on RS v6.1 or v6.0. couldn't remember what's the exact version. Other cores should be fine.
How to get this evaluation licence??I will be using rs encoder sysgen block ,I am download xilinx ise 30 days trial and matlab 2012a .Will this work??and please tell me how to get this licence
Please ask this question to the Installation and Licensing forum or the DSP - IP and Algorithms forum.
http://forums.xilinx.com/t5/Installation-and-Licensing/bd-p/INSTALLBD
http://forums.xilinx.com/t5/Digital-Signal-Processing-IP-and/bd-p/DSP
However, I expect you can get this from the Xilinx licensing page.
Kind regards,
Ambrose
