Visitor pg1003
Regarding Xilinx GATEWAY IN Block in Simulink
Hi. I am facing a problem while using Xilinx blockset in Simulink. I am feeding an ECG input signal to the "GATEWAY IN" Block and at the output of the "GATEWAY IN" Block, my signal get distorted. I am attaching the input as well as output signal for your reference.     I want my output signal same as input signal. I feel this problem is due to sample period value selected in "GATEWAY IN" Block. This GATEWAY IN block does not take value less than 1 and due to it, the output is not the same as input. Kindly help.
Participant caccolillo
Re: Regarding Xilinx GATEWAY IN Block in Simulink
Have a look at the xilinx system generator token, in the "clock" panel.
You should find the relationship among system clock and simulink period.
Visitor pg1003
Thanks a lot Sir. It is working to a great extent. I am still fine tuning it.
Visitor pg1003
It is working. I am getting desired signal at the output of GATEWAY IN block. Thanks a lot.
