Register Enable sampling Problem
Hi, I am trying to sample the output at a specific cycle, I use a counter to measure the specific cycle and enable the sample register, but the simulation seems not working, can anyone give some help?
Re: Register Enable sampling Problem
sorry guys, I am just keep being stupid.
the output of the 3rd wave was not considered for the delays, so the enable signal was enabling the reg when input were zeros.
:smileyindifferent:
the simulation wave form.
the enable pulse has covered the 2 cycles, but the output is still 0, why is this?
:smileyindifferent:
