lewismclaughlin
Running System Generator 2019.1 in MATLAB 2019a from Command Line
I would like to open System Generator 2019.1 from the command line and pass in a string to be executed in MATLAB.
I am using MATLAB 2019a.
Before, this was possible by doing:
sysgen -r "disp('test string')"
However, now I am greeted with a warning and disp() is not executed:
Warning: Command line argument -r cannot be combined with subsequent -r argument.
sysgen -batch "disp('test string')"         also does not work, giving:
Command line argument -r cannot be combined with subsequent -batch argument.
ERROR: MATLAB error Exit Status: 0x00000001
I believe this problem is because of something which has changed in MATLAB from 2019a. Also, I would like to leave sysgen.bat as is.
Has anyone managed to achieve this in 2019a or does anyone have a solution?
Many thanks,
Lewis.
ravidapu
It seems like Mathworks has changed start up options behavior from R2019a and Sysgen is not inline with those options, it will be a bug in sysgen because if which the following is not working
-batch option is used for non interactive runs, can you try the following and see
sysgen -nodesktop -batch "disp('test string')"
Raju A.
lewismclaughlin
Hi Raju,
Thanks for getting back to me.
I tried the line you sent and received:
I agree with your assessment that Mathworks have changed the startup behavior from 2019a. This makes line 480 in sysgen.bat incompatible with further uses of -r or -batch.
Editing this file to accept more arguments works well for an individual user, however it is not ideal if you would like for scripts you write to be used by other people.
Kind regards,
Lewis.
hijo86
Hallo,
i have the same problem with XILINX 2019.2 and Matlab 2019b. It seems, that the problem is not solved in the further XILINX Releases.
Do you have a work-around to start SystemGenerator with Matlab commands?
This problem damages our complete automated code generation workflow.
Best Regards
Johannes
