Set Part in Xilinx Sysgen token from the environment
Hi all,
I have a sysgen simulink design in Vivado 2018.2/Matlab 2017b that's used for two different FPGA targets. Is there a way to programmatically set the Xilinx token's Part selection to be something arbitrary? Otherwise, changing the part in the GUI changes the .slx file and will appear as a changed file in revision control.
Thanks!
回复: Set Part in Xilinx Sysgen token from the environment
add_part(family, device, speed, package, temperature)
An example of an explicit command is add_part(‘Kintex7’, ‘xc7k325t’, ‘-1’ , ‘fbg676’,‘’). If the part-related API’s are not used, the end user can select any device that he wants to choose from the list.
Ran this at Matlab's prompt (started from the Xilinx sysgen launcher, sysgen toolboxes are available) to try to get the xilinx environment class:
xilinx.environment.addCompilationTarget('Impl', strcat(pwd, '/Impl'))
addpath(strcat(pwd, '/Impl'))
The Impl directory was created with no problems, path is added.
I can now do this at the prompt:
>> obj
obj =
  Impl with properties:
      tcl_command_list: {}
             file_list: {}
      top_level_module: ''
      compilation_flow: 'Project'
    custom_project_dir: ''
           target_name: {'Impl'}
           device_list: {}
                   hdl: ''
        synth_strategy: ''
         impl_strategy: ''
             create_tb: ''
      create_iface_doc: ''
Moving forward, I still want to set the device, or the HDL, or whatever. Is this what I need to do from now on?
obj = Impl;
setup_sysgen_token(obj)
obj.add_part('ZynqUP', 'xczu9eg', '-2-e', 'ffvb1156'
Last line fails predictably, the auto-generated Impl.m class makes add_part a protected function so the method can't be called from the class instance.
How is this supposed to be handled?
