curtisra
Simulating a Simulink Subfunction in Questa
I am looking for an example of the files I need to generate in order to simulate a System Generator Subfunction in Mentor Graphics Questa simulator.
I have tried generating an hdl_netlist from System Generator using the system generator block.  Vivado completes and there is an hdl netlist directory, but I am not sure which files are required.
An example would be helpful if available.
Thanks for any help you can offer.
vkanchan
Hi @curtisra ,
When a netlist is generated in System generator, it automatically creates a Vivado project in the hdl_netlist directory.
Open the project in Vivado, configure the simulator settings to Questa sim and simulate.
For details on how to simulate a Vivado project using Questa, please have a look at below links:
https://www.xilinx.com/video/hardware/simulating-mentor-questa-in-vivado.html
https://www.xilinx.com/content/dam/xilinx/support/documentation/sw_manuals/xilinx2019_2/ug900-vivado-logic-simulation.pdf
