Simulation error in Xilinx FIR compiler
Hello all,
Im simulating an FIR filter which does interpolation by a factor of two, and I keep receiving this simulation error:
interpolator_2_inst/U0/g_mac/mac/ : Warning: NUMERIC_STD.TO_SIGNED: vector truncated
What can cause this? XCO file of filter is attached
first of all, it's no error, but a warning.
Warnings highlight situations that can lead to malfunction but they can be ignored if the design can deal with such situations.
So you have to decide.
Truncation in MAC structures is one solution to keep the word width in a reasonable size.
Another method would be rounding. Both cause some loss of information, but have different influence on the stability of your filter.
So, if your filter is stable with truncated values everything is just fine.
Use Matlab for a comprehensive test of your filters numerical stability.
Have a nice synthesis
  Eilert
  Eilert
Yes of course, you are correct. It is no error, my mistake! :smileywink:
I have simulated the filter chain and analyzed the outputs of respective filters using octave.
The filter precision (and noise..) is within our tolerance, both in simulation and synthesis.
I am using the non-truncated output of the filters. I round the output outside the filter core itself.
In conclusion, everything works ok, I was just wondering if this something I should consider investigating more.
