Observer droid77
Standard Exception Error in System Generator v14.2
Matlab R2010a 64 bit
Windows 7 64 bit Pro
I recently get this error while trying to generate a model file...
standard exception: XNetlistEngine:
An exception was raised:
com.xilinx.sysgen.netlist.NetlistException: ERROR:sim - Failed to run command ' -p xc6slx45-3csg324 -sd "C:/TEMP/sysgentmp-Eduardo Rey/cg_wk/ccf99782f14da4fdd/tmp/_cg/_dbg/" -sd "C:/TEMP/sysgentmp-Eduardo Rey/cg_wk/ccf99782f14da4fdd/tmp/_cg/" -dd "C:/TEMP/sysgentmp-Eduardo Rey/cg_wk/ccf99782f14da4fdd/tmp/_cg/_dbg/" "addsb_11_0_05b67e10f20c24b3" "C:/TEMP/sysgentmp-Eduardo Rey/cg_wk/ccf99782f14da4fdd/tmp/_cg/addsb_11_0_05b67e10f20c24b3.ngc" -intstyle xflow'. Executable file not found.. More information can be found in C:/TEMP/sysgentmp-Eduardo Rey/cg_wk/ccf99782f14da4fdd/coregen.log or in C:/depot/ECG3_SD/system/sysgen/coregen.log.
Reported by:
Unspecified
Please help, I tried uninstalling and then re-installing Matlab with no success.  I thought it might be a corrupted model file but I opened up files that did not have any issue generating pcore before and now they all show this error message when trying to generate.
I have reviewed the following pages but have not come up with a solution:
http://www.xilinx.com/support/answers/29430.htm
http://forums.xilinx.com/t5/DSP-Tools/standard-exception-XNetlistEngine-error-using-System-Generator/td-p/29140
http://www.xilinx.com/support/answers/23614.htm
I have also uninstalled latest update from Java to see if that was it but it also did not solve the problem.
Any help would be greatly appreciated.
Ed
Re: Standard Exception Error in System Generator v14.2
It sounds like the matlab environment is not set up properly.
Are you making sure to launch sysgen from the Windows Start menu (i.e. not just through matlab/simulink) ?
www.xilinx.com
Observer droid77
Yes I am running System Generator from C:\Xilinx\14.2\ISE_DS\settings64.bat location.
Okay. When you run this command from matlab/sysgen, are your $XILINX environment variables set:
>> !env
www.xilinx.com
Observer droid77
Hello and thank you for following up on this...
Attached is a snapshot of my environment variables
Below is Matlab/SysGen output when I ran the !env command:
>> !env
ALLUSERSPROFILE=C:\ProgramData
AMDAPPSDKROOT=c:\Program Files (x86)\AMD APP\
APPDATA=C:\Users\Eduardo Rey\AppData\Roaming
CommonProgramFiles=C:\Program Files (x86)\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=EE_WORKSTATION
ComSpec=C:\Windows\system32\cmd.exe
EMC_AUTOPLAY=C:\Program Files (x86)\Common Files\Roxio Shared\
FPPUILang=en-US
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Users\Eduardo Rey
INSTALLMLLOC=C:\MATLAB\R2012a\bin\matlab.exe
KMP_HANDLE_SIGNALS=0
LOCALAPPDATA=C:\Users\Eduardo Rey\AppData\Local
LOGONSERVER=\\EE_WORKSTATION
MATLAB_ARCH=win64
NO_XILINX_DATA_LICENSE=HIDDEN
NUMBER_OF_PROCESSORS=2
OnlineServices=Online Services
OOBEUILang=en-US
OS=Windows_NT
Path=C:\MATLAB\R2012a\bin\win64;C:\Xilinx\14.2\ISE_DS\ISE\sysgen\bin\nt64;C:\Xilinx\14.2\ISE_DS\ISE\lib\nt64;C:\Xilinx\14.2\ISE_DS\ISE\bin\nt64;C:\Xilinx\14.2\ISE_DS\PlanAhead\bin;C:\Xilinx\14.2\ISE_DS\PlanAhead\lib;C:\Xilinx\Vivado\2012.2\bin;C:\Xilinx\14.2\ISE_DS\EDK\bin\nt64;C:\Xilinx\14.2\ISE_DS\EDK\lib\nt64;C:\Xilinx\14.2\ISE_DS\EDK\gnu\microblaze\nt64\bin;C:\Xilinx\14.2\ISE_DS\EDK\gnu\powerpc-eabi\nt64\bin;C:\Xilinx\14.2\ISE_DS\EDK\gnuwin\bin;C:\Xilinx\14.2\ISE_DS\EDK\gnu\arm\nt64\bin;C:\Xilinx\14.2\ISE_DS\common\bin\nt64;C:\Xilinx\14.2\ISE_DS\common\lib\nt64;c:\Program Files (x86)\AMD APP\bin\x86_64;c:\Program Files (x86)\AMD APP\bin\x86;%CommonProgramFiles%\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\Program Files (x86)\Common Files\Roxio Shared\10.0\DLLShared\;C:\VXIPNP\WINNT\BIN;C:\VXIPNP\WINNT\TekVISA\BIN;C:\MATLAB\R2012a\bin
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
Platform=nt64
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_ARCHITEW6432=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 37 Stepping 5, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=2505
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC=C:\Users\Public
RoxioCentral=C:\Program Files (x86)\Common Files\Roxio Shared\10.0\Roxio Central36\
SESSIONNAME=Console
SYSGEN_CACHE_ENTRIES=2000
SYSGEN_CACHE_SIZE=40000
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\TEMP
TMP=C:\TEMP
USERDOMAIN=EE_workstation
USERNAME=Eduardo Rey
USERPROFILE=C:\Users\Eduardo Rey
windir=C:\Windows
XCOPE=C:/Xilinx/14.2/ISE_DS/ISE/sysgen
XILINX=C:\Xilinx\14.2\ISE_DS\ISE
XILINX_DSP=C:/Xilinx/14.2/ISE_DS/ISE
XILINX_EDK=C:\Xilinx\14.2\ISE_DS\EDK
XILINX_PLANAHEAD=C:/Xilinx/14.2/ISE_DS/PlanAhead
XILINX_VIVADO=C:\Xilinx\Vivado\2012.2
XIL_SG_CONTEXT=1
xlnxInstLocList= common EDK common/CodeSourcery PlanAhead ../../Vivado/2012.2 ISE ../../Vivado_HLS/2012.2
__KMP_REGISTERED_LIB_5012=000000006D0D8D10-cafe410f-libiomp5md.dll
