Supporting decimation changes on-the-fly
Hi All,
It seems the System Generator FIR Compiler blocks do not provide for a reloadable decimation (or interpolation) factor, is that correct?  My application requires that I be able to change the decimation on the fly (and the decimation is not necessarily a power of two).  I see these as options:
1) Implement N FIR filter blocks, each with its own sample rate change;
2) Use the FIR in single rate mode, followed by N DownSample blocks (each with a unique downsample factor) in parallel;
3) Use the FIR in single rate mode, followed by an MCode block that can downsample by a programmable factor;
4) Use a CIC filter (which does support programmable sample rate changes) in combination with a FIR.
Has anyone had to deal with this problem?  Is one of the above “solutions” better than the others?  Is there some alternative anyone can suggest?
L M C
