Switch between Matlab debug interface(Jtag) and Tera Term(Uart)
When i run debug interface for DPD from Matlab, tera term freezes. Even when i close the interface i am not able to use Tera term. It is blocked. I have to restart the board. How do i stop JTAG connection from Matlab and get the control back to Tera term via UART
Re: Switch between Matlab debug interface(Jtag) and Tera Term(Uart)
HI Lakshya,
We are working on it through sevice-request. I will update the forum page with final results.
  1. It looks to be failing an initial version check issue. Are you using the same version of Vivado i.e. to generate the image as well as DPD Matlab interface.
  2. Other issue worth checking is that clock/reset is applied correctly to system brought up using SD-Card.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
