Sygen Fifo bug in 2019.1?
I just upgraded from System generator/Vivado 2016.4 (Matlab 2015a) to 2019.1 (Matlab 2018b).
There seems to be a bug with Fifo Genrator if the reset input is used:
ERROR: [Synth 8-448] named port connection 'srst' does not exist for instance 'core_instance0'...
This error appears for all IPs generated in Sysgen as long as the reset port for FIFOs is used.
All the FIFOs are used for cross domain clocking. I do not have any FIFO with reset in the same domain.
I compared the genrated code between the versions:
2016.4:
if (core_name0 == "ddr3_tfr_fifo_generator_v13_1_i1")
begin:comp1
ddr3_tfr_fifo_generator_v13_1_i1 core_instance1 (
.rd_clk(rd_clk),
.wr_clk(wr_clk),
.rst(rst),
.din(din),
.wr_en(wr_en),
.rd_en(rd_en),
.dout(dout),
.full(full),
.empty(empty),
.rd_data_count(dcount)
end
2019.1:
if (core_name0 == "ddr3_tfr_fifo_generator_i1")
begin:comp1
ddr3_tfr_fifo_generator_i1 core_instance1 (
.rd_clk(rd_clk),
.wr_clk(wr_clk),
.srst(rst),
.din(din),
.wr_en(wr_en),
.rd_en(rd_en),
.dout(dout),
.full(full),
.empty(empty),
end
there is a clear difference between .srst(rst), and .rst(rst), port connections
after changing this manually in the entity declaration file, I can synthesis/compile successfully.
Looks like this is a bug?
Regards Markus
This is not reproducible for me in 2019.1 release. I tried with small fifo design and settings used are
  • Block memory configuration for FIFO
  • Compilation target in sysgen token is HDL netlist
Can you provide us .slx file to reproduce the problem, also state the fifo configuration and token settings ?
Raju A.
Hi Raju,
sorry for the late reply. I have been on vacation for the week.
I have attached a stripped down version with basically just the CDC logic and FIFO. It has the issue when code is generated.
Regards Markus
Thanks for sharing the design.
It seems like this issue with Verilog and its a bug. As a work around, you can use VHDL instead of verilog in order to proceed with your design.
Hope it helps.
