SysGen Gateway In Unexpected Overflow error
Hello All,
I am seeing a weird behavior with the gateway in block.
Below is an example,
I have a constant block with value 8589934591 which is a 33 bit max value.
My gateway in have the same fixed point settings as the input,
When I run the simulation, I see an overflow error. Why? It requires exactly 33 bits!
Am I missing anything obvious.
Also I do not see this behavior for values which require 32 bits or less!
Any input is appreciated!
Bhavanithya Thiraviaraja
Tags (2)
Re: Gateway In Unexpected Overflow error
I think that's a question for Mathworks, as the errors comes in Matlab simulation, right?
Well, it includes both matlab constant block and also the xilinx dsp Gateway In. I don't know yet which of these is the reason for this  behavior!
@bhavanithya
Yes, that's true, these blocks come from Xilinx.
I'm afraid in this case they will just blame each other. It happens with Windows and software.
We have reproduced the issue at our end. Currently, we are checking the source of error.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
HI @bhavanithya @archangel-lightworks
  1. SysGen Gateway-in block first converts its input data type to ‘double’ format then convert it into UFix_33_0 type. So irrespective of any Simulink type (e.g. uint32, double fixed), first it will be converted into ‘double’ as standard notation and then it will be processed to destination type specified in GateWay-In block.
  2. Matlab has little different behavior with regard to values of double and fixed point format as shown below. You can see that value for 2^33 is different for double and unsigned fixed format.
  3. Also, both 8589934591 and 8589934592 have the same values as "8589934591" for ufix33 format (this behaviour can not be seen in less than 32 bit).
3. Issue: Now the values are converted from ufix to double in sysgen before sending to gateway in. And due to above conflict in the values, SysGen throws the simulation error due to 'flag as error' option. The difference in above figure is causing the overflow
Workaroud: Set the output data type to ‘double’and enter the input value as 8589934591 or 2^33-1 (not as 2^33).
Hi @meherp
2^33 (8589934592) value requires 34 bits to represent it. That is the reason why it is saturtating it to the maximum number that can be represented by 33 bits which is 8589934591 (as seen from your screenshots) and this is the expected behavior.
My problem is different,
I give 8589934591 as UFix33 (which is representable as proved in the above screenshot) to gateway In with 33 bits and gateway says it is an overflow. !!!
When given as double, of course it works but I want to know why it does not work for UFix constants. My input signal needs to be in UFix format for specific reasons.
There are multiple (specific) workarounds which we did for our design,
  1. As said, it can be given as double.
  2. Overflow type = wrap
  3. Arithmetic Type = "signed"
However no.3 may not work for other designs.
But I am only curious why exactly Simulink UFix33 Constant does not go with Xilinx UFix_33_0 gateway In!
Actually, it is not saturating to max value. If you try '8589934593' for ufix33, then overflow error will be shown by Matlab as well; whereas the '8589934592' is converted to '8589934591'.
During the conversion 'from fixed to double' by SysGen, the conversion of (2^33) 8589934591 value from “ufix33” into “double”, makes the value 8589934592 due to the floating-point conversion (precision) issue. This is the reason for overflow (i.e. overflow in simulation). In the other words, ufix33 has max value 8589934591, but during conversion it will appear as 8589934592 to gateway in port, therefore sysgen is throwning error on it.
The 'wrap' option doesn't care about the simulation overflow, but you may see warnings if MATLAB and SysGen simulation does not match.
Hello Mr.Patel,
thank you for your reply.
Okay so if I understood right, you are saying 8589934591 is getting converted into 8589934592 due to some precision issue (fix to double). 8589934592 needs 34 bits and not 33 so there is an overflow.
But in the screenshot you uploaded ufix_33 8589934591 is not converted to 8589934592 and also the same when I tried in my simulink.
Also in matlab when I try to convert fixed to double I do not see this happening.
Additionally, I observed that all the numbers which requires 33 bits i.e from 4294967296 to 8589934591 had an overflow when fed to the 'gateway in' with 33 bit. How do I make sense of this with your explanation?
