wpunchak
Sysgen 2018.2 and Matlab R2018A are seemingly NOT compatible
@anatoli recommended that I re-raise the issue I had described in the Installation and Licensing forum here.
Originally, I questioned whether Matlab R2018a is supported with SysGen 2018.2 because of the misleading documentation I had found on this articled Xilinx question: https://www.xilinx.com/support/answers/55830.html
@anatoli had confirmed that this was probably a mistake and that Xilinx UG973 - Page 6 indicated that Matlab R2018a is supported with SysGen 2018.2.
However, when I tried to see test that Matlab R2018a is compatible with SysGen 2018.2, I ran into the following issue:
After creating a simulink project in Matlab R2018A, I added a Xilinx System Generator Block. If I then double click this System Generator Block I get the following error:
Do you know how to resolve the above error?
I'm not confident that SysGen 2018.2 is compatible with Matlab R2018A.
wpunchak
I re-ran the System Generator Configurator:
* Remove Matlab R2018a so that it's no longer configured
* Relaunch System Generator Configurator
* Mark Matlab R2018a as configured
After doing the above, I'm no longer seeing the errors and SysGen seems to be working again.
I'm not sure why it needed to be redone...
chenjianliang
I can successfully install and connect them.
And even build some simple projects.
But I found that some IP blocks would assert ERROR when simulating.'[USF-XSim-62] 'elaborate' step failed with error(s)' in system generator 2018.2 when simulating DDS module
I'm not sure whether they are just the 'same' compatible problem
wpunchak
@anatoli / xilinx employees,
Here are the errors being output to Matlab's command window after double clicking the System Generator block from a simulink model:
Warning: Error evaluating 'ModelCloseFcn' callback of Xilinx System Generator Block block (mask) 'xbsIndex_r4/ System Generator'.
Callback string is 'xlSysgenGUI('Close',gcs,gcbh);'
Warning: Undefined variable "com" or class "com.xilinx.sysgen.util.EnvironmentUtil.isSgPaServerOn".
Warning: Error evaluating 'DeleteFcn' callback of Xilinx System Generator Block block (mask) 'xbsIndex_r4/ System Generator'.
Callback string is 'xlSysgenGUI('delete', gcs, gcbh);'
Warning: Cannot open 'xbsIndex_r4' while it is being closed.
Warning: Error evaluating 'ModelCloseFcn' callback of Xilinx System Generator Block block (mask) 'PDWSimDraft1/ System Generator'.
anatoli
Hello @wpunchak,
1) To me, this is due to SysGen bad/corrupt installation. Can you try reinstalling this into some different location (that you'd have full admin rights) to what you'd done your previous SysGen installation?
2) Can you confirm please, have you installed a new version of System Generator for DSP (v2018.2) into the same directory as the old version e.g. v2017.2?
3) Also, are you able to open Matlab on its own, without using SysGen?
I just want to double check and see if the problem is actually with the Matlab itself (rather than SysGen), as SysGen triggers Matlab.
Therefore, if you navigate to ...../matlab/bin/matlab.exe and try to start matlab directly from this directory, does it work or not?
4) Also, if you right-click on SysGen and do "Run as Administrator", can you start System Generator 2018.2 as admin without seeing the above Warning/Error?
5) Actually, is this just a warning that you can click on "Ignore" to ignore this, or an error and this doesn't let you to proceed any further? The reason i'm asking is because the message above states:
Can you please confirm on the above points?
If you have any questions for me, please let me know.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
wpunchak
Hello @anatoli,
See my responses, below in orange.
I tried uninstalling and reinstalling Vivado/System Generator 2018.2. I'm still seeing the same described issue.
I have already uninstalled Vivado 2017.2.
The only Xilinx products that I currently have installed on my machine are:
- Model Composer 2018.2
- Vivado with System Generator for DSP 2018.2
- SDK 2018.2
- SDK 2017.2
I can launch and use standalone Matlab 2018a without any issues.
No, I still see the same error when running as administrator.
The error message dialog only has an "OK" button. After clicking OK, the System Generator dialog which contains the tabs Compilation/Clocking/General does not appear.
Confirmed.
wpunchak
@anatoli, I've found a work around for the time being:
1) Drop the System Generator block into my simulink model file.
2) Save and Close the simulink model.
3) Exit Matlab / System Generator.
4) Relaunch System Generator.
5) Open the simulink model.
6) Double click the System Generator block.
I'll still see the error I described above, but after clicking OK, the dialog will open with this workaround.
anatoli
Hello @wpunchak,
Thanks for your response on the questions asked and for letting us know that you have now managed to workaround this issue.
Unfortunately, I've done all I could from my side to help you out with this issue as much as possible, however this is now something above my knowledge, as I am not a SysGen expert and have no idea why this Warning/Error occurs in your case.
However, I'm glad to hear you have managed to figure out a WA for this issue and at least you can now continue with your design.
Thanks once again and have a nice day.
Kind Regards,
Anatoli Curran,
Versal Blogs
wpunchak
I appreciate your help @anatoli...is there anyone else out there from Xilinx who can help?
The problem is worse when I select any other Xilinx block...
Here's the prompt I see when I click on a newly added Constant Block:
Along with this error message:
Warning: The following error was caught while executing 'xlSocketServer_impl' class destructor:
Undefined variable "com" or class "com.xilinx.sysgen.socketinterface.NativeMatlabInterface.getInstance".
Error in xlNMIProxy
Error in xlNMIProxy
Error in xlSocketServer_impl/delete
Error in xlSocketServer_impl.getInstance
Error in xlXBlockGUIClass
Error in xlOpenGui
> In xlSocketServer_impl
  In xlSocketServer_impl.getInstance
  In xlSocketServer
  In xlXBlockGUIClass
  In xlOpenGui
After selecting OK, no other dialogs appear and I cannot edit the properties of the Xilinx block...
Just a reminder, here are my specs:
- Freshly reinstalled System Generator 2018.2
- Matlab r2018a
- Windows 10 Desktop
wpunchak
Even if I just try to open up the xlDoc from the Matlab Command Prompt I get the following:
Type xlDoc to open the Xilinx System Generator help documentation.
Type demo blockset xilinx to view the demos available for Xilinx System Generator.
Tip of the day: Learn more about Resource Analyzer.
>> xlDoc
Undefined variable "com" or class "com.xilinx.sysgen.XFixJavaLoader.load".
wpunchak
arve9066
I am using System Generator 2018.3 and MATLAB r2017b. Whenever I open the demos from the demo blockset xilinx I get the error
Error: Unable to obtain waveform database.
Undefined variable "com" or class "com.xilinx.sysgen.XFixJavaLoader.setClassLoader".
Warning: Error evaluating <sldiag objui="callback" objparam="ModelCloseFcn"></sldiag> callback of Xilinx System
Generator Block block (mask) 'sysgenQAM16/ System Generator'.
Generator Block block (mask) 'sysgenADCDAC/ System Generator'.
But if I follow the tutorials given in this link - https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug948-vivado-sysgen-tutorial.pdf - I do not encounter any error. I am not sure what is the reason for the error happening during the demos
mrbietola
the solution proposed worked for me also, thank you!
