derrickgw
System Generator 11.1 in linux
I am trying to use the new Linux functionallity of System Generator, but am running into some issues.
Whenever I open a model I get the following errors:
Warning: xbsIndex_r4.mdl, line 7: Error evaluating 'PreLoadFcn' callback of block_diagram
'xbsIndex_r4'. Invalid MEX-file
'/net/fpga2/xilinx/11.1/DSP_Tools/lin/sysgen/bin/xlmeta.mexglx':
/net/fpga2/xilinx/11.1/DSP_Tools/lin/sysgen/bin/../lib/libregistrationid.so: undefined
symbol: Sec_Checkin.
> In general/private/openmdl at 13
  In open at 153
  In uiopen at 196
Warning: xbsIndex_r4.mdl, line 7: Invalid MEX-file
  In open at 153
  In uiopen at 196
Warning: xbsCopyrightNotice_r4.mdl, line 7: Error evaluating 'PreLoadFcn' callback of
block_diagram 'xbsCopyrightNotice_r4'. Invalid MEX-file
  In open at 153
  In uiopen at 196
Warning: xbsCopyrightNotice_r4.mdl, line 7: Invalid MEX-file
  In open at 153
  In uiopen at 196
If I try to run the model, every System Generator block has the error:
Error evaluation parameter 'ptable_' in [block name]: Undefined function of vriable 'ptable_'
Which means that it is not calling the mask initialization code, which sets 'ptable_'. I suspect that the error opening the model is contributing to that.
I don't think it is a path error, because it can find the mex-file, it just doesn't like it. Linux thinks that it is a valid executable, so I know that the file is not corrupted.
I am running CentOS 5.3 (RHEL5.3 clone)
Any ideas?
Tags (3)
derrickgw
Thanks for suggesting ldd. After running that I realized what the problem was:
$ ldd /net/fpga2/xilinx/11.1/DSP_Tools/lin/sysgen/lib/libregistrationid.so
        linux-gate.so.1 =>  (0x00c13000)
        libpthread.so.0 => /lib/libpthread.so.0 (0x0041c000)
        libSecurity.so => /net/fpga2/xilinx/10.1/ISE/lib/lin/libSecurity.so (0x0027c000)
        libstdc++.so.6 => /net/fpga2/xilinx/10.1/ISE/lib/lin/libstdc++.so.6 (0x00110000)
        libm.so.6 => /lib/libm.so.6 (0x001f0000)
        libc.so.6 => /lib/libc.so.6 (0x00478000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00f07000)
        /lib/ld-linux.so.2 (0x0045c000)
My paths were still being setup for the 10.1 tools, even though I changed my bashrc to use the 11.1 tools. I couldn't find where I was calling the 10.1 settins script, so I just cleared LD_LIBRARY_PATH before calling the 11.1 script.
benchan
Did you run the settings32.sh / settings32.csh script in the top level directory of your ISE Design Suite installation (/net/fpga2/xilinx/11.1)?
Please make sure that the ISE lib directory (/net/fpga2/xilinx/11.1/ISE/lib/lin) is in $LD_LIBRARY_PATH.
Ben
derrickgw
I was running the settings file, but did not have ISE 11.1 in the LD_LIBRARY_PATH. Unfortunately, adding it did not seem to solve the problem.
benchan
What shell are you using? Is your machine a 32-bit or 64-bit machine? Please check if you invoke the right settings script:
  • 32-bit Linux with bash shell: xilinx/11.1/settings32.sh
  • 32-bit Linux with csh shell: xilinx/11.1/settings32.csh
  • 64-bit Linux with bash shell: xilinx/11.1/settings64.sh
  • 64-bit Linux with csh shell: xilinx/11.1/settings64.csh
The script should add xilinx/11.1/ISE/bin/lin or xilinx/11.1/ISE/bin/lin64 to $PATH, and xilinx/11.1/ISE/lib/lin or xilinx/11.1/ISE/lib/lin64 to $LD_LIBRARY_PATH.
If you don't see these settings after running the settings script, something wrong happened.
As the error message indicates a library dependency issue, you can run ldd to check what's missing.
derrickgw
