System Generator 11.3 Hardware-co-simulation Timing Constraint error
I'm using Spartan 3E Starter Kit Board, and now I want to make simulation using Hardware Co-simulation, but after XFLOW run, it showed that there was 1 timing constraint not met.
I have done some search before making this post. Although there were some topics about this error before, but I still find it so confusing for me to understand this situation.
When I finish my design with model in MATLAB (3 Mult, 2 AddSub and 1 Delay), I create SGBD Builder exactly as Performing Hardware-in-the-Loop PDF file guide. After that, I generate and it show 1 timing constraint not met:
  Constraint                                |    Check    | Worst Case |  Best Case | Timing |   Timing
                                            |             |    Slack   | Achievable | Errors |    Score
* TS_hwcosim_sys_clk = PERIOD TIMEGRP "hwco | SETUP       |     5.086ns|    14.914ns|       0|           0
  sim_sys_clk" 50 MHz HIGH 50%              | HOLD        |    -3.743ns|            |    5420|    11072268
  TS_J_TO_U = MAXDELAY FROM TIMEGRP "J_CLK" | SETUP       |    10.315ns|     4.685ns|       0|           0
   TO TIMEGRP "U_CLK" 15 ns                 |             |            |            |        |
  TS_clk_70d40e76 = PERIOD TIMEGRP "clk_70d | MINPERIOD   |    18.348ns|     1.652ns|       0|           0
  40e76" 20 ns HIGH 50%                     |             |            |            |        |
  NET "jtag_iface/drck1" PERIOD = 30 ns HIG | SETUP       |    22.981ns|     7.019ns|       0|           0
  H 50%                                     | HOLD        |     0.974ns|            |       0|           0
I thought using hardware co-simulation that means System Generator automatically match Timing Constraint, if it needs to be changed, should I change in file SGBD Builder s3e_starter.ucf in folder \Xilinx\DSP_Tools\nt\sysgen\plugins\compilation\Hardware Co-Simulation\s3e_starterkit?
Message Edited by phongduong on 01-16-2010 11:46 AM
_______________________________________________________________________
there 10 types of people in the world: those who knows binary and those who don't
Re: System Generator 11.3 Hardware-co-simulation Timing Constraint error
total path delay should be less than clock period (20 ns in this case for Spartan 3E) and thus slck variable shoild not be negative.
I have got the same problem. Has anyone found a solution?
