cwboyd18
System Generator: Error 0001: Fatal Internal Error
I'm trying to work through the System Generator Tutorials and I am getting the following error when I try to run one of the examples (Lab 1_1). Can anyone provide advice on how to fix this error? I have a permanent license for sysgen with a version limit of 2018.5. I noticed that I do not have any Xilinx environment or system variables set on my machine, could that be part of the issue?
--------------------------------- Version Log ----------------------------------
Version Path
System Generator 2017.3 C:/Xilinx/Vivado/2017.3
Matlab 9.1.0.441655 (R2016b) C:\Program Files\MATLAB\R2016b
Vivado 2017.3 C:/Xilinx/Vivado/2017.3
Summary of Errors:
Block: 'Lab1_1/Digital FIR Filter'
Error 0001:
Reported by:
Details:
An internal error occurred in the Xilinx Blockset Library.
Please report this error to Xilinx (http://support.xilinx.com),
in as much detail as possible. You may also find immediate help
in the Answers Database and other online resources at http://support.xilinx.com.
Since it is possible that this internal error resulted from an
unhandled usage error in your design, we advise you to carefully
check the usage of the block reporting the internal error. If
errors persist, we recommend that you restart MATLAB.
Error occurred during "Simulation Initialization".
balkris
please make sure to open the sysgen by clicking sysgen token
Thanks and Regards
Balkrishan
meherp
Please follow the below step and let us know if it helped,
1. please check the folder C:/.xilinx and delete the license file from there.
2. Save your license file in some folder e.g. c:/licenses (not in the C:/.xilinx).
3. Go to license manager and select this license.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
