System Generator - Linux - not working any longer
Hi everyone,
I'm using System Generator 11.1 and Matlab R2008a under Xubuntu and everything worked fine after installation.
Now I have the problem that I can not configure the Xilinx-Blocks any more. The errormessage on the matlab console is:
Exception from xlsession_env
Warning: The following error was caught while executing
'xlSocketServer' class destructor:
Undefined variable "com" or class
"com.xilinx.sysgen.socketinterface.NativeMatlabInterface.getInstance".
> In
/opt/Xilinx/11.1/DSP_Tools/lin/sysgen/bin/xlXBlockGUIClass.p>xlXBlockGUIClass.xlXBlockGUIClass
at 33
In /opt/Xilinx/11.1/DSP_Tools/lin/sysgen/bin/xlOpenGui.p>xlOpenGui at
110
 has anyone an idea to get it work again? thanking you in anticipation!
Re: System Generator - Linux - not working any longer
there was no change after updating to ise 11.4, but updating matlab to 2009b solved the problem! hope it works longer now ;)
Any luck solving this problem?  I'm seeing it too.  It appears >100 people have viewed your messag, but no replies.  I'm guessing a lot of people are having a problem?
Thanks!
no. i am sorry, but i don't have a new awareness concerning this problem.
any solution is still welcome!
the realy confusing thing is that it worked for a while. with you also?
I'd been working in the PC realm until some license server problems prompted me to try the Linux side.  Same intermittent license server problems, but I think this problem has constantly occurred for me in Linux.  Will post if we ever figure out the problem.
Try entering the following in the matlab prompt:
 xlAddSysgen(getenv('XILINX_DSP'));
I work with windows and  xlAddSysgen(getenv('XILINX_DSP')); worked for me - thanks respectmyprivacy
Reply,but this is not working with me,m running matlab 2010 with ISE 12.2.
Please suggest some other solution.
Thank you! I had the same problem and I was already using Matlab 2009b, but driving xlAddSysgen(getenv('XILINX_DSP')); on a matlab promt solved this.
Abbas_0612000, Ensure you use the supported version of the tools, see AR: http://www.xilinx.com/support/answers/17966.htm
