System Generator - mask parameters and MCode
This is a visibility issue that I haven't yet found an efficient way around it. Basically, I would like to access the parent block mask parameters from within my MCode (statemachine). I want this to be done at compile time as I need to make my code parametrizable.
Would appreciate any input on this.
Mani
The "Interface" tab of the MCode block allows you to equate an input to your function to a constant or a variable with the "Bind to value" field.
Take a look at the help for the MCode block for details on passing parameters to your block.  A variable set in the interface tab can be defined in the MATLAB workspace or in a mask variable.
If you have further qeustions please open a webcase with Xilinx Support
Many thanks Jeffrey, sorted.
Mani
