System Generator simulation correctness
I'm designing an IIR filter on Zynq7. I use SysGen to create the filter ip core.
To implement IIR filter, I use all AddSub, Mult and Constant (for coefficients) with the floating point option and zero latency.
When I simulate it on SysGen (MATLAB), the result is exactly what I expect.
However, when I implement all on my development kit, the result is so weird. I want to ask whether the SysGen behavior is exactly the same with the real behavior?
Thank you,
Dung
Hi @dzungnh95 ,
Sysgen is bit and cycle accruate hardware modelling tool. So the simulation will match that of hardware.
Can you check if the correct clocking parameters are passed in your sysgen token ?
which version of vivado/sysen is being used ?
Did you check the behavioral simulation of the generated code in Vivado simulator ? Any difference here ?
If the board is a Xilinx evaluation board , can you check the Hardware Co-sim and report any differences ?
Hi @dzungnh95 ,
