ajaymanyam
System Generator
This is the error i get when i try to run my matlab simulation
--------------------------------- Version Log ----------------------------------
Version Path
System Generator 2018.3 D:/Xilinx/Vivado/2018.3
Matlab 9.4.0.949201 (R2018a) Update 6 D:\Matlab
Vivado 2018.3 D:/Xilinx/Vivado/2018.3
Summary of Errors:
Error 0001: Error("test1.m"): Syntax error: Encountered " <INTEGER_LI...
Block: 'lcfilter/MCode'
Error 0001:
Reported by:
'lcfilter/MCode'
Details:
Error("test1.m"): Syntax error: Encountered " <INTEGER_LITERAL> "1
"" at line 4, column 6.
"1 "" at line 4, column 6.
Error occurred during "Block Configuration".
meherp
@ajaymanyam
Not all the matlab function can be implemented on the Hardware. Therefore MCode block does not accept all the functions of Matlab.
For more details, please see the section "MCode" of UG958 (pg 215).
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
ajaymanyam
The mcode file doesnt have any predefined matlab functions. Every line of the code is written using algorithms
meherp
Is it possible to share the code.
