System generator IP
I made an IP from System Generator Here I found in the script of the IP
ATTRIBUTE DowngradeIPIdentifiedWarnings : STRING;
ATTRIBUTE DowngradeIPIdentifiedWarnings OF data_0_arch: ARCHITECTURE IS "yes";
COMPONENT data IS............
What does it say
Is there some thing wrong in it ??
Uzmeed
Hi @uzmeed ,
The generated IP contains scripts for integration to Vivado. Do you face any issues with using the IP in Vivado IP integrator ?
I was able to generate the IP correctly and then add in the IP list in vivado
It was also called successfully in the verilog code
But when I integrate it with rest of the code it does not work
I have two modules one is the sys gen IP and other is a verilog based ethernet firm ware
Ethernet firm ware works correctly with any type of test data
when I connect the output of sys gen IP with ethernet code data is some how scrambled or some times completely wrong data is received
I have checked using ila and found that sys gen ip is also giving correct output
There is some thing wrong in the interfacing
Both modules are running at same clock
Best Regards
uzmeed
