farzadetemadi
System generator and LDPC
Does System Generator support HDL generation from Simulink for LDPC IP, such as the one below? If so, what tool versions should be used? (MATLAB and Vivado)
https://www.xilinx.com/products/intellectual-property/ef-di-ldpc-enc-dec.html
Farzad
balkris
no LDPC block not available Sysgen Library . You required to use through Vivado design flow
Thanks and Regards
Balkrishan
nathanx
I think the LDPC encoder/decoder is not added into System Generator library, however, you can generate the LDPC encoder/decoder in Vivado, then import the IP into System Generator using Blackbox component in SysGen.
balkris
Thanks and Regards
Balkrishan
