doner_t
System generator error: stray '\375' in program
I try to simulate the example demo of the system generator  : Two Dimensional FFT using Corner Turning Tecnique...
However below error is received. It is seen mostly related to c/c++ compiling of the DSP48E simulation sources. Is there any solution offer?
Error 0001:
Reported by:
'sysgenMRI_2D_FFT/Corner_Turn_Memory/DSP48_MUX/DSP48E1 '
Details:
:/Users/$/AppData/Local/Temp/sysgentmp-$/.xlmcode_work/xlDSP48E1/11b8/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:1:
warning: -fPIC ignored for target (all code is position independent)
C:/Users/$/AppData/Local/Temp/sysgentmp-$/.xlmcode_work/xlDSP48E1/11b8/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:
In function 'xlsim_update':
C:/Users/$/AppData/Local/Temp/sysgentmp-$/.xlmcode_work/xlDSP48E1/11b8/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:896:
warning: integer constant is too large for 'long' type
C:/Users/$/AppData/Local/Temp/sysgentmp-$/.xlmcode_work/xlDSP48E1/11b8/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:988:
error: expected '=', ',', ';', 'asm' or '__attribute__' before '_3_626_5'
error: '_3_626_5' undeclared (first use in this function)
error: (Each undeclared identifier is reported only once
error: for each function it appears in.)
Best regards,
nathanx
Can you try to reduce the logic to only have the DSP48E included in the model? Is the issue still present?
nathanx
doner_t
Dear @nathanx,
Sorry for this big delay. I missed my this post.
I reduce the example design to only DSP48E blocks. When I run the simulation, sysgen_error_log file is seen as below;
Summary of Errors:
Error 0001: Undriven input port
Block: 'sysgenMRI_2D_FFT_03112018/Corner_Turn_Memory/DSP48_MUX/DSP48E1 '
Error 0002: Undriven input port
Block: 'sysgenMRI_2D_FFT_03112018/Corner_Turn_Memory/DSP48_MUX/DSP48E1 1'
Error 0001:
Reported by:
Details:
The input ports on this block must be driven by other Xilinx blocks
Error 0001:
Reported by:
Details:
Thank you so much,
@doner_t
Tags (2)
doner_t
Dear @nathanx,
I have tried the same example with Vivado 2018.1 and Matlab 2017b.  Exactly the same error is seen here. You can see log file below. I have changed the DSP48 blocks in design with some other DSP48 in library. But the result is not changed.
--------------------------------- Version Log ----------------------------------
Version Path
System Generator 2018.1 D:/Xilinx/Vivado/2018.1
Matlab 9.3.0.713579 (R2017b) C:\Program Files\MATLAB\R2017b
Vivado 2018.1 D:/Xilinx/Vivado/2018.1
Summary of Errors:
Error 0001: C:/Users/AppData/Local/Temp/sysgentmp/.xlmcod...
Block: 'sysgenMRI_2D_FFT_orig/Corner_Turn_Memory/DSP48_MUX/DSP48E1 '
Error 0001:
Reported by:
Details:
:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/4668/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:1:
C:/Users/AppData/Local/Temp/sysgentmp-/.xlmcode_work/xlDSP48E1/4668/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:
C:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/4668/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:896:
C:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/4668/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:988:
C:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/4668/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:1755:
C:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/4668/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:1791:
C:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/4668/0/40622002/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:2619:
error: 'mux_c' undeclared (first use in this function)
error: expected ';' before '_3_626_5'
Program
"D:/Xilinx/Vivado/2018.1/tps/mingw/4.4.3/win64.o/nt64/bin/x86_64-w64-mingw32-gcc.exe"
returned non-zero status (1).
Error occurred during "Simulation Initialization".
Tags (2)
nathanx
If you have DSP48 block only, you still need to drive the inputs of DSP48 block, otherwise you will get errors.
It sounds like the error persists for every sysgen design? Is that true? Can you try a very simple sysgen design, with an adder, and two inputs sent to adder, and a output?
Have you tried to run Vivado Simulator? Is it working?
Have you tried to re-install the tools(Vivado)?
doner_t
Dear @nathanx,
I have tried basic adder, it works properly. In addition, I have tried the a few system generator examples design given under the Vivado\2018.1\examples\sysgen_demos file.They also works properly in 2018.1 System Generator (Matlab 2017b).
I have also tried the DSP48E1 block only as seen below. I have received the above same error as given log below. Probably problem in this DSP48E1 block.
Version Path
Summary of Errors:
Block: 'sysgenMRI_2D_FFT_deneme/DSP48E1 '
Error 0001:
Reported by:
Details:
:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/36bc/c0000000/40886188/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:1:
C:/Users//AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/36bc/c0000000/40886188/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:
C:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/36bc/c0000000/40886188/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:896:
C:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/36bc/c0000000/40886188/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:988:
C:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/36bc/c0000000/40886188/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:1755:
C:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/36bc/c0000000/40886188/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:1791:
C:/Users/AppData/Local/Temp/sysgentmp/.xlmcode_work/xlDSP48E1/36bc/c0000000/40886188/555c4c86a73ca69ae3a28a56f5b6c8ab/xlsim.c:2619:
Program
Thank you,
@doner_t
Tags (2)
doner_t
Dear @nathanx,
Below the some extra details;
*Why do I try to run this example (sysgenMRI_2D_FFT) design --> I need to implement/simulate 2D FFT in system generator by using Xilinx 1D FFT block. This example design contains 2D-FFT. If you have a different implementation of 2D FFT, you can offer it.
*Could you please try to run sysgenMRI_2D_FFT example of System Generator in your own PC?
*My PC operationg system is Windows-10.
Best Regards,
@doner_t
nathanx
I have tried the demo, it works, my os is Win7, however, I don't think this is due to the different OS, have you tried to re-install Matlab?
doner_t
@nathanx,
Thank you for trying. I have also tried this example design on a Win-7 PC. It works properly. Sure, I have tried the Matlab re-installing. But, problem is seen again.
In my Win-10 PC, I have modified the example design a little. That is basicly replacing the all DSP48 blocks (only there are 2) in design with MUX. Because DSP48 block in this design used for multiplexing purpose. Now, example design works properly in my Win-10 PC.
Thank you,
Tags (2)
