The config_tdata_pinc port of DDS Compiler 6.0 1 in Programmable mode
Hi everyone,
I'm using DDS compiler 6.0 1 in System Generator 2015.4. The Virtex 7 FPGA clock frequency is 250MHz and I want to generate a 10MHz sine wave.
In the configuration of DDS compiler, I selected hardware parameters and the phase width is 30.
So I calculated that the phase angle increment values as follows.
PhaseIncrementValue = (10e6 * 2^30)/250e6 = 42949672.96
Since the config_tdata_pinc port of DDS Compiler expects unsigned fix_point 30_30 input. I calculated the value of pinc as
pinc = PhaseIncrementValue/2^30 = 0.04
However, it seems that this configuration is incorrect, since the DDS output is a constant value 1.
Here I attached my block design in System Generator. Can anyone help me check it?
Thank you very much.
Tong
Re: The config_tdata_pinc port of DDS Compiler 6.0 1 in Programmable mode
Hi @austin
I found out the problem. Sorry I made a very stupid mistake. I connected the Gateway Out with data_tvalid instead of data_tready.
The value of the constant should be 0.04, since the config_tdata_pinc port requires Fixed_30_30 input.
The result is good after the modification.
In my understanding, the clock source is from a FPGA pin which has been linked with a clock chip on FPGA board. But we don't need to specify the pin location while implementing DSP algorithms in System Generator. The clock capable pins won't show up until the Xilinx IP has been generated from System Generator design.
Tong
Scholar austin
42949672.96 is the constant,
(42,949,673 as the integer used to set the frequency)
Austin Lesea
Principal Engineer
Xilinx San Jose
@austin
Hi Austin,
Thank you very much. I modified my design and set the constant to 42,949,673, but the result still remains the same. I don't know where went wrong.
I also tried to use the "Constant" block from Xilinx, but the result is still incorrect.
Is there any other possible mistake?
Tong
Scholar austin
Where is the clock?
Austin Lesea
Principal Engineer
Xilinx San Jose
@austin
Thank you.
I configured the clock in "System Generator" block. The clock frequency is 250MHz.
Tong
Scholar austin
Where is the source of this clock?  I do not see it coming in through an IBUFG on a clock capable pin and being named....
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi @austin
Tong
Scholar austin
Great!
I am glad you found it.  I was just suggesting things that might have been incorrectly done.
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi @austin
I'm so glad that the problem has been solved.
Tong
