Observer wangxiaoliang
The problem of FFT IP core
Re: The problem of FFT IP core
It's basically a simulation problem. You didn't compile myfft in the do file. Add "vlog myfft.v" before running vsim command will sovle the problem
Hi:
I'm sorry.There is no content in my question.What is that I creat two projects,in which I do the same thing.But now fft4 can work ,while the other cannot.
Where are the problems? The transcripts are in it.
Wish for your help!
Hi:
The error messege is this:
# Top level modules:
#  fft_top
# Model Technology ModelSim SE vlog 6.3c Compiler 2007.09 Sep 11 2007
# -- Compiling module glbl
#  glbl
# vsim -L xilinxcorelib_ver -L unisims_ver -L unimacro_ver -lib work -t 1ps fft_top glbl
# ** Note: (vsim-3812) Design is being optimized...
# ** Error: fft_top.v(61): Module 'myfft' is not defined.
# Optimization failed
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./fft_top.fdo PAUSED at line 7
PLZ HELP
Thank you! The problem is solved. But why the problem is in verilog, not in vhdl?
excuse me, can anybody tell me why I get zero results from fft when I simulate using ISE simulator. I don't know about verilog very much but I think I did the same in VHDL, however when I tried to simulate your file I got zero results.
please help me ASAP, I am in a bad need to know how this core works please.
Hello:
If you have output,that means the core works in a right way,maybe you should check your testbench,and the timing.
Visitor imranqureshi
plz set 500ns time then check!
set 500us simulation time
Visitor deba_techno
i have tested the rar fft4 code, with 500us just for experimenting. got "0" result. can u sir, plz fix the problem.
