Timing issue with Sysgen but no timing issue in ISE
I've imported a VHDL design to the Sysgen model and encountered the timing issue. However when I ran in the ISE with the same timing constraint, I didn't get the timing issue.
Does anyone know why I have this problem? How to modify the design according to the timing report?
Thanks in advance.
Scholar austin
Re: Timing issue with Sysgen but no timing issue in ISE
m,
Everytime you place and route, different paths may be used, and timing violations may appear.
Timing closure  involves examining the failing path, an then re-architecting, rewriting rtl, use of placement constraints, etc. to resolve.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_3/ug612.pdf
http://www.xilinx.com/training/fpga/timing-closure-video.htm
Austin Lesea
Principal Engineer
Xilinx San Jose
Thank you for your reply.
