sofiene
Urgent ! Hardware co-simulation (Simulink/Xilinx) on ML505 board
Hello everybody,
I’m new in Xilinx forums and Xilinx working
In fact, my goal is to try a hardware co-simulation (Simulink/Xilinx) on my ML505 (Xilinx XUPV5-LX110T) board, and I’m still in the step of board-PC wiring, I still try to communicate them through an Ethernet cable, so I’m in the initial step,
I did all the indicated steps in the System Generator for DSP User Guide v12.4 (I followed the same steps as Installing an ML506 Board for Ethernet Hardware Co-Simulation):
-          I configured my IP address on 192.168.8.2
-          I formatted the flash card with FAT16 and I unzipped the ML506_sysace_cf.zip file inside the card: so in the flash card we find : cfg.dat, ip.dat, mac.dat, xilinx.sys and a folder named “hwcosim”, in this folder we find too sub-folders named “dut” and “boot4” that contains respectively dut.ace and boot4.ace
-          I set the Configuration Address DIP Switches as follows:  1:on, 2:off, 3:off, 4:on, 5:off, 6:on, 7:off, 8:on
-          I set the Ethernet Mode Select jumpers as shown in the attached picture (the default position of jumpers) which is the same picture at the page 293 of  System Generator for DSP User Guide v12.4
-          I installed the Ethernet RJ45 male/male straight cable.
Normally, if all is well done, the MAC and IP addresses of the board will be displayed on the LCD displayer. But I have nothing and even when I pressed the System ACE™ Reset button to reconfigure the FPGA. And worse, the Error LED in the board glows red, what means really I have an error in my configuration process.
I’m totally blocked, please if someone has any idea to correct.
Thank you in advance,
Best regards,
Sofiene
ywu
The XUPV5-LX110T board has a xc5vlx110tff1136-1 device on it, otherwise it's identical to ML505. Below is the link to the board where you can find more information about the board.
http://www.xilinx.com/products/boards-and-kits/XUPV5-LX110T.htm
HWCOSIM needs a clock from the board, this is why you need to set up the pin location and frequency for the system clock input. You can use the "USER_CLK" input on the board. I will leave it to you to find out the location and frequency in the documentation.
For JTAG HWCOSIM, no special configuration is required.
Yes, you will need a JTAG download cable connecting the board to your PC.
@sofiene wrote:
Hello
Thank you very much for responding,
Just I want to ask you some questions:
My board is XUPV5-LX110T, so how can I choose the appropriate:
- speed grade ?
- package ?
- pin location ? And what does mean this parameter in the case of HWCOSIM ? i.e. pin of what exactly ?
- system clock ?
Is there a special configuration necessary of  "Configuration DIP SW" and/or jumpers ?
The board must be connected by the JTAG programming cable or JTAG configuration cable ?
Sofiene
Cheers,
Jim
sofiene
Please it's very urgent, if anyone has a comment !
eteam00
Professor
Professor
It's 4AM on the USA west coast.  Not a lot of people online right now.
Hey, cross-posting 3 duplicate threads in 3 different forums is considered rude, and is unnecessary.  Duplicate threads will not improve your chances of a quick response.
-- Bob Elkind
SIGNATURE:
Summary:
sofiene
Hello
Sorry, but I just thought that maybe the thread is not in the right place. I know that it can’t improve my chances of a quick response.
Thanks to be more fluent.
---Sofiene
sofiene
Hello
Please if anyone has an experience with ML505 and exactly XUPV5-LX110T board, tell me about the easier Board/PC way of connection (JTAG or Ethernet) for a successful HW co-sim.
Thank you in advance.
ywu
The HWCOSIM plugin is board specific. You can't use the ML506 Point to Point Ethernet plugin for your ML505 board. It's very easy to create a JTAG HWCOSIM for any board. Please check the link below for step-by-step instructions. You can ignore the NMM part if you don't need them.
http://myfpgablog.blogspot.com/2009/12/sysgen-create-new-hwcosim-target-with.html
@sofiene wrote:
Hello everybody,
Best regards,
Sofiene
Cheers,
Jim
sofiene
Hello
- speed grade ?
- package ?
- system clock ?
Sofiene
ywu
@sofiene wrote:
Hello
- speed grade ?
- package ?
- system clock ?
Sofiene
Cheers,
Jim
sofiene
Hello
Thank you so much, it was very helpful
Sofiene
