Visitor arivu
Using PC-CFR IP
I am trying to use the PC-CFR v6.2 IP for my project. Should I initialize the IP through SDK? It will be really useful if you can help me out with an example design or any document that shows how to use the IP effectively.
Thank you.
回复: Using PC-CFR IP
PC-CFR does not have driver, so you can not initilize the IP through SDK(using driver), the PC-CFR IP provides Matlab simulation scripts which can help the user to run simulation.
Visitor arivu
回复: Using PC-CFR IP
Thanks for clarifying.
