Observer learni
Using a single DSP48E2 Slice to infer three 48-bit inputs adder
Hi All,
I have nine 8-bit values that I want to add using the dsp slices.
As an example I tried this code from the Xilinx answer records(https://www.xilinx.com/support/answers/66429.html).
I want to implement the second approach: "Two of the inputs are free to come from any source and one input comes from an internal DSP48 feedback signal as in a MAC."
But after synthesis even the original verilog code is inferring 2 DSP slices.
Am I interpreting things wrong or is there any bug in the code?
I created this VHDL equivalent of the Verilog code from Xilinx.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity tri_adr is
   GENERIC(
		CONSTANT SIZEIN  : NATURAL := 48; 	-- Input size
		CONSTANT SIZEOUT : NATURAL := 48 	-- Output size
   PORT(
		 clk          : in STD_LOGIC;	-- Clock
		 resetn_glb   : in STD_LOGIC; 	-- Global Reset from the Zynq PS
		 resetn_lc    : in STD_LOGIC; 	-- Local Reset if necessary
		 operand_i1   : in  STD_LOGIC_VECTOR (SIZEIN-1 downto 0);	-- 1st input to dsp
		 operand_i2   : in  STD_LOGIC_VECTOR (SIZEIN-1 downto 0);	-- 2nd input to dsp
		 operand_i3   : in  STD_LOGIC_VECTOR (SIZEIN-1 downto 0);	-- 3nd input to dsp
		 avg_out      : out STD_LOGIC_VECTOR (SIZEOUT-1 downto 0)	-- Averged output
attribute USE_DSP : string;
attribute USE_DSP of tri_adr: entity is "YES";
end ENTITY;
architecture behav of tri_adr is
   signal a    : std_logic_vector (26 downto 0);
   signal b    : std_logic_vector (17 downto 0);
   signal pcout    : std_logic_vector (SIZEOUT-1 downto 0);
   signal avg_t    : std_logic_vector (SIZEOUT-1 downto 0);
begin
avg:PROCESS (clk)		--check every clk
	begin
		if rising_edge(clk) then
			if resetn_glb = '0' then	--negative assert
				avg_t <= (OTHERS => '0');
				pcout <= (OTHERS => '0');
			else
				pcout  <= std_logic_vector((signed(a) * signed(b)) + signed(operand_i1));
				avg_t  <= std_logic_vector(signed(pcout) + signed(operand_i2) + signed(operand_i3));
--				avg_t  <= std_logic_vector(signed(operand_i1) + signed(operand_i2) + signed(operand_i3));
			end if;
		end if;
	end PROCESS;
	-- Output result
	avg_out <= avg_t;
end behav;
I will be adding three 8-bit numbers using one DSP slice and create a cascaded adder logic to do addittion of all nine values.
Thanks in advance.
Best regards.
Tags (2)
Re: Using a single DSP48E2 Slice to infer three 48-bit inputs adder
I may be missing something but where are values for signals a and b assigned?
Scholar jmcclusk
you can't do that.   Ternary addition in the DSP48E2 can only be done if you DON'T use the multiplier.   The output stage of the multiplier needs 2 of the 3 adder inputs.    But I think you will be frustrated in actually getting DSP48E2 inferral to work exactly the way you want.    Your best bet is to instantiate the DSP48E2 yourself and then configure it the way you want.    But I don't see any easy or simple way to use the DSP48E2 to produce the sum of 9 values, since you can really only pump in fresh data through the A:B and C ports.
But in adding 9 values of 8 bits, why not use slice logic?  Ternary adders work very well in the fabric, and an 8 bit ternary adder will run at 500 MHz.    This should  only take 5 slices and 2 clock cycles in an Ultrascale device.
Observer learni
Thanks for mentioning it.
I made them Inputs but the result was same.
Best regards.
