davidsteffen
VCK190 aie file missing
I booted the board under the guidence of the tutorial at vck190 wiki page. After login the linux prompt, I found that the mentioned file aie-matrix-multiplication under the path /lib/firmare is missing. And there is no instructions about where should I get the file, neither the tutorial nor the github page.
Could someone tell me how to solve the problem. Thanks a lot.
Tags (3)
florentw
HI @davidsteffen
The github example was removed. This was just a quick example for board bring up to have the aie running but it was not really a good example of an aie application.
What exactly are you trying to achieve here?
Florent
davidsteffen
Thanks for your relpy!
I am a newbee for both vitis and vivado and I just want to follow the guidence of the tutorial hahaha. Simply, I want to get an example on how vck190 run AI inference speed up applications. Maybe an example of how it run deep learning model(e.g. VGG-16 or ResNet-50) is better, if possible.
Thank you for your reply anyway.
florentw
Hi @davidsteffen
I am not much knowledgeable on this side. This can be done using Vitis AI (with the Xilinx DPU).
You might want to ask how to get started on the AI and Vitis AI board.
Florent
