Observer nagender_patel
VIvado system generator sample time error uint32
hello
i have  taken a simple sine wave in simulink (xilinx sysgen)
frequency 1khz
sample time 200usec
blocks are arranged as shown below
i am getting the error
The periodic sample time 1000000.0 is not allowed because the ratio of this sample time over base rate (0.0002) is greater than the maximum value of uint32.
Re: VIvado system generator sample time error uint32
can anyone please reply to solve this error
Use relative rates by normalizing the simulink sample period to the hardware clock rate settings.
www.xilinx.com
Visitor sagar
please any one to help for fft simulation in vivado??
Please reduce the sample time which is specified as "1000000.0" or go to system-generator token and change the frequency there. It will remove the error.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
