alexboin
Verify fft Core in sysGen
Hi friends,
I want to test xilinx fft core7.1,but i can not get the right answer even for simplest signals,
I attach an image,Tell me if you can guess my mistake.
bwiec
How are you concluding that it is incorrect? What is the expected response?
How are you configuring the FFT? What is your simulink system period (set in the SysGen token)? What data type/rate are you setting in the gateway in for your data?
www.xilinx.com
alexboin
I attached my matlab simulink file.
My input signal is just a sine wave,so i have only one frequency(but i find diffrent values in fft result)
the configuration is 8k point pipelined fft with 64MGHz Simulation frequency,13 bti phase factor width,unscaled,and natural order.
gateway_in data type is fixed point 14 bit with 13 binary point.
thanks for your answer.
bwiec
You forgot to attach your model.
www.xilinx.com
alexboin
bwiec
First, your FFT is only 512 long. Thus, looking at your 8K deep ROM with 1 period of a sine wave in it, keep in mind that you are only sending in 1/16 of a period for each FFT.
Secondly, you need to use xk_index (and rdy) to qualify your data. If you look at the image below, you see only one spike per FFT frame.
www.xilinx.com
bwiec
If you change the FFT to 8k and run the sim a bit longer (and zoom in!), you will see what I suspect is more of the result you are looking for:
www.xilinx.com
alexboin
Thanks for your answer my friend.
I can't see ur images,and i want to know what exactly tells me checking the value & its index?
also my result is sth like image below.
i visited http://myfpgablog.blogspot.com/2010/07/fft-results-from-matlab-fft-bit.html
but i could not verify my result yet,because i can't run the
Bit Accurate C model presented there
thanks
bwiec
You are just about there. Now just zoom in on one full period of the ramp in the x-direction and zoom in on the data a bunch in the y-direction. I've attached the picture this time so you can download it.
www.xilinx.com
