12-17-2020 04:17 AM - edited 01-07-2021 01:21 AM
This post lists the useful resources related to the Versal ACAP AI Engine (AIE)
1. Documentation Resources
2. Example Designs/Applications
3. Blog Articles
4. Main Answer Records
The Versal ACAP AI Engine Design Process Hub can help you find the documentation resources you need base on your current development stage:
https://www.xilinx.com/support/documentation-navigation/design-process/ai-engine-development.html
This is the list of the main documents for AI Engine Development:
AM009 - Versal ACAP AI Engine - Architecture Manual
UG1076 - Versal ACAP AI Engine Programming Environment (HTML Version) - (PDF Version)
UG1078 - Versal ACAP AI Engine Intrinsics
UG1273 - Versal ACAP Design Guide
Super Sampling Rate FIR Filters
Runtime Parameter Reconfiguration
AI Engine Versal Integration for Hardware Emulation and Hardware
Versal ACAP AI Engines for Dummies
Xilinx Versal AI Engine Series
AR#75837 - Xilinx AI Engine Solution Center
AR#75802 - DSP Library (DSPLib) for AI Engine - Release Notes and Known issues
