selune
Viterbi Decoder IP architecture
Hello guys,
I was wondering what is the difference between Viterbi decoder serial and parallel architecture? Can I get faster decoding speeds if I use the parallel one? And if so, how can I know the speeds in question? Thank you in advance.
Kind regards.
selune
balkris
Parallel architecture give you high data throughput and serial arch used for smaller area footprint.  The decoder core consists of two basic architectures: a fully parallel implementation which gives fast data throughput at the expense of silicon area and a serial implementation which occupies a small area but requires a fixed number of clock cycles per decoded result.
serial implementation requires a fixed number of clock cycles per decoded result.
You can compare the resources here
https://www.xilinx.com/support/documentation/ip_documentation/ru/viterbi.html
Thanks and Regards
Balkrishan
balkris
Thanks and Regards
Balkrishan
mhilley
Does the Viterbi Decoder v9.1, when placed in Parallel Mode, still process only 1 input bit at a time.  Like when it is in serial mode.
