Visitor hyfsysu
What algorithm does Xilinx use for division and square-root in the Floating-Point Operator IP?
I have read the document " Floating-Point Operator v7.1 LogiCORE IP Product Guide ". In Chapter 4 page 33, it says:
Cycles per Operation
The Cycles per Operation Vivado IDE parameter describes the minimum number of cycles
that must elapse between inputs. This rate can be specified. A value of 1 allows operands to
be applied on every clock cycle, and results in a fully-parallel circuit. A value greater than 1
enables hardware reuse. The resources consumed by the core reduces as the number of
cycles per operation is increased. A value of 2 approximately halves the resources used. A
fully sequential implementation is obtained when the value is equal to Fraction Width+1 for
the square-root operation, and Fraction Width+2 for the divide operation.
I know there are some common algorithms for divison and square-root, such as non-restoring, newton-raphson, goldschmidt, SRT. According to the above description, I guess it uses non-restoring.
Can anyone give me some information?
回复: What algorithm does Xilinx use for division and square-root in the Floating-Point Operator IP?
Unfortunately the algorithm info can not shared.
